Architectural drawings dimension to the top of a floor or slab / never to the bottom. Make the Floor command uder the AEC menu, and the Object info pallete for Floors display the delta Z height at the top of the floor.
The way it's set up now, I have to subtract the slab / floor depth every time I set a floor. It's a waste of time and brain power.
And if you change the slab thickness for some reason everything has to be adjusted, like wall and window heights, all your layer heights too.
Say for example, in Schematic Design you worked with a 6" slab, and then later the Structural Engineering calc's tell you the slab needs to be 8" of concrete. Building it into the program so that you can do this seemlessly makes sense.
Set it up so it's more intuitive, based on how architects draw and design the building; not an arbitrary number that must be calculated each time.
reem
3 answers to this question
