Wireframe Data Visualization with Solid Colors
19 minutes ago, Pat Stanford said:
The only think I can think of is to use stacked viewports with different render modes. Set the back one to only show the lights and other things you want colored. Set the front to show the things you want in hidden line.
I think this will be tricky because the lights want to be in the middle rather than at the back...
Could you render the VP in Shaded with edges turned off then apply Hidden Line foreground render + then use Data Vis to apply colours to the lights then a second Data Vis to give the other objects a white fill...?
@Cristiano Alves We do not use Hidden Line Rendering - In place Open GL (Shaded) is set with No Texture @David Gil has this above  - No Shadows - No Ambient Occlusion  - Up the Ambient Brightness
The set up: Need to have a color applied to the items you want colored and no color to what will be lines only
Attached - One page Open GL with Textures - One page without
Peter
Hidden Line vs Open GL_01.pdf
2 minutes ago, Cookie_NZ said:
Hi @Cristiano Alves.  How about running two Data Vis?  One which colours the lighting devices.  And another which colours everything which isn't a lighting device white.
Lighting Data Vis only:
Adding 'Not lighting device' Data Vis
Not LX Data Vis:
Snap 🙂
