Flared Staircase help
gavinv
Hi Gavin,
Don't know why your are being blocked from the main Forum.  Are you logged out?  Anyway as per your message, below is the file of the Stairs only.
1 - Edit group will separate some sections.  You could remove a section.  I backed it up to 2020 in case you don't have a current version of VW's.
2- To scale the entire object, first group it.   This will give you handles to scale.
If you need railing help, just ask.
GAVINV v2020.vwx
