DFlores Posted November 2 Share Posted November 2 Hello, I installed the new version of vectorworks landmark 2025 and the tool "creat objects from shapes" is not working. Don't even even access the menu. Does anyone else have this problem? Any ideas to solve it? Thanks Quote Link to comment
0 Pat Stanford Posted November 3 Share Posted November 3 Are you using a custom workspace? Have you tried one of the default workspaces? If custom, try editing the workspace to remove and then add the command back in. Sometimes there are changes made to commands and the workspace still has the old version. Quote Link to comment
0 DFlores Posted November 3 Author Share Posted November 3 Thank you for the suggestion. I actually had a custom user for landmark worksapce. As suggested, I tried to remove and add the tool from the menu but without success!! Any additional suggestions? Thanks Quote Link to comment
0 Jonathan Pickup Posted November 3 Share Posted November 3 this works for me, do you have the correct type of object selected? Quote Link to comment
0 DFlores Posted November 3 Author Share Posted November 3 1 hour ago, Jonathan Pickup said: yes it is very strange. I kept a 2024 version and tested it without any problems. In 2025 I don't know why the command doesn't respond. Not even the next menu appears!! I already tried to reinstall it but it stayed the same! Quote Link to comment
0 michaelk Posted November 3 Share Posted November 3 7 hours ago, DFlores said: Thank you for the suggestion. I actually had a custom user for landmark worksapce. As suggested, I tried to remove and add the tool from the menu but without success!! Any additional suggestions? Thanks Have you tried a stock workspace? Quote Link to comment
0 DFlores Posted November 5 Author Share Posted November 5 On 11/3/2024 at 9:06 PM, michaelk said: Have you tried a stock workspace? Yes, the same. Don´t work... Quote Link to comment
0 michaelk Posted November 5 Share Posted November 5 Can you make a screen capture movie? In a blank document draw a rectangle, select it, then try to do a Create Objects from Shape… Quote Link to comment
0 DFlores Posted November 5 Author Share Posted November 5 Hello michaelk, thanks for trying to help. here's the video. 20241105-1808-08.2224439.mp4 2 Quote Link to comment
0 DFlores Posted November 11 Author Share Posted November 11 Thank you to everyone who tried to help resolve the issue. The command became functional after updating to 2025.01 Quote Link to comment
DFlores
Hello,
Thanks
10 answers to this question
