sharpegaz Posted October 31, 2024 Share Posted October 31, 2024 Hi, I am having trouble with the speaker array tool and Hoists. I have looked through the forums and on YouTube and am still at a loss on what to do. For example, if I inset a fly frame, be it a default frame or say an L'acoustics K1 frame, when I go to attach the hoists I am left with only limited options. If I have multiple hoists set I can attach it to a KS28 fly frame, and get the side points, but when I run Braceworks it refuses to run it as says essentially only 2 hoists active, which would be the correct amount to fly it. When I then drop it down from multiple hoists to two hoists it reduces the arena I am unable to attach them to and puts them on top of each other, this is also the same with the default. Then when I use a frame like a K1 frame or default frame, I get the same result, when I try to attach to the main fly bar, it will only let me chose a point on the fly frame and not across the fly bar. Is this a bug, as the only way I can get any feedback from Braceworks is it I overlay points in places they physically would never be located. Any and all hope is truly appreciated. Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted November 1, 2024 Vectorworks, Inc Employee Share Posted November 1, 2024 I believe you can only attach hoists to the generic bumpers as the Bumper content does not include the rigging point information. So if you can try with a generic bumper then this should work. I will defer to my colleagues on the content team to confirm this. Quote Link to comment
