sharpegaz Posted October 31, 2024 Share Posted October 31, 2024 Hi, I am having trouble with the speaker array tool and Braceworks. I have looked through the forums and on YouTube and am still at a loss on what to do. For example, if I inset a fly frame, be it a default frame or say an L'acoustics K1 frame, when I go to attach the hoists I am left with only limited options. If I have multiple hoists set I can attach it to a KS28 fly frame, and get the side points, but when I run Braceworks it refuses to run it as says essentially only 2 hoists active, which would be the correct amount to fly it. When I then drop it down from multiple hoists to two hoists it reduces the arena I am unable to attach them to and puts them on top of each other, this is also the same with the default. Then when I use a frame like a K1 frame or default frame, I get the same result, when I try to attach to the main fly bar, it will only let me chose a point on the fly frame and not across the fly bar. Is this a bug, as the only way I can get any feedback from Braceworks is it I overlay points in places they physically would never be located. Any and all hope is truly appreciated. Quote Link to comment
