RogerPDX Posted October 29, 2024 Share Posted October 29, 2024 I've created a plant key worksheet that includes images of the plant symbols. However, a handful of the symbols stay too small and don't match the size of the cell. See attached screenshot. Any ideas what's causing this? I tried changing the cell heights and recalculating the worksheet but it didn't affect the size of those symbols. Quote Link to comment
Pat Stanford Posted October 30, 2024 Share Posted October 30, 2024 Edit the worksheet and select the database header row cell for the column with the image (ie A3, not A3.1, A3.2, etc.) From the Worksheet menus select Format:Cells and then choose the Images pane. Check that you have Autosize selected. If you do and it is not working properly, try Fixed and set the size so it matched you cell dimensions. HTH 1 Quote Link to comment
RogerPDX Posted October 30, 2024 Author Share Posted October 30, 2024 That worked, thank you! It needed to be set to Fixed. Once I did it for one cell, it sized the others correctly as well. Quote Link to comment
