Is it important to store working files offline and not on the same server as the Project File?
We are dipping our toes into project sharing and I came across this web page:    Link.  On the whole it is as I expected, except for one thing:
"It's important to save your working file on your local desktop and avoid saving it on a server or in the cloud."
Can anyone clarify if this is important and if so, why is it?
I am sure there is a more technical reason, but my thoughts are.
If the internet/network goes out, I can keep working on my local working file until I can sync again.
If the server gets corrupted. I have a local copy I can convert my working file to a regular VWX file and then back into project to get back going again.
Basically, 2 files in 2 places are safer than 2 files in the same place.
All of this assumes you have a robust backup system on your local machine.
  • 2 weeks later...
I believe it is suggested to not only save the working file in a different location, but ideally in a location that does not get backed up (such as Time Machine, Dropbox, Gdrive, etc).  Unless you are doing a lot of project file work that you are not saving back to the project file, there really is no reason to have backups of your working file; you can always create a new one.
 The reason, as I understand it is that occasionally your working file will get backed up in a background process and confuse the project file into recognizing two of your working files. The result is the frustrating issue of not being able to work on a file because the other ghost “you” has items checked out. When that has happened, I save the project file as a standard VWX file and then convert it back to a new project file. Very annoying.
I've found that it is important to have your working file on your local drive and not sync w/ dropbox.  We tried it and it caused problems.  My understanding is that the syncing methodology can cause … bad things.  It certainly caused object permissions to get messed up.  I think @scottmoore is describing the same issue.
But if you are running your own server it might be different.
