domer1322 Posted October 29, 2024 Share Posted October 29, 2024 I can't figure out this simple question .... how do you manipulate the interior wall surfaces of a roof dormer ? In the attachment you'll see the exterior walls have gray vinyl siding, but so does the interior wall surface. How do I change the texture on the interior dormer wall without changing the exterior wall texture ? thanks in advance for help ... Quote Link to comment
Tom W. Posted October 29, 2024 Share Posted October 29, 2024 This is just the way it is with Dormers unfortunately. The only thing I know is to Ungroup the Roof or Roof Face which will convert the Dormer into separate Walls, Window + Roof Faces which will allow you to then render the dormer walls individually by object + so apply different textures to left + right sides. 1 Quote Link to comment
Catmansound Posted November 13, 2024 Share Posted November 13, 2024 On 10/29/2024 at 2:32 PM, Tom W. said: This is just the way it is with Dormers unfortunately. The only thing I know is to Ungroup the Roof or Roof Face which will convert the Dormer into separate Walls, Window + Roof Faces which will allow you to then render the dormer walls individually by object + so apply different textures to left + right sides. I have the same problem, and I'm not an advocate for exploding intelligent objects into individual parts, as a designer, I'm constantly experimenting and showing client's different ideas, so being able to manipulate the interior side of a dormer while it is a "dormer" is more efficient way of designing, and exactly the intent of these intelligent objects. Quote Link to comment
Tom W. Posted November 13, 2024 Share Posted November 13, 2024 45 minutes ago, Catmansound said: these intelligent objects That's a very generous description 🙂 1 Quote Link to comment
