Vectorworks crashes when D5 Render proggram starting
Novruz
12 answers to this question
  • Administrator
@Novruz , could you please share more details so we can better assist you? Specifically, which version of Vectorworks and operating system are you using? It also appears that the YouTube video is unavailable. If you’d prefer, you can always reach out through our support portal at https://customers.vectorworks.net/support. Thanks
@JuanP i am sorry about video link, mu bad.
Now it is open, you can check.
Susytem info
HI, I'm having similar problems, just upgraded to the new Vectorworks 2025, Update 1 (Build 780313) crashes constantly while working in D5. Sometimes it just crashes after I click the fire up D5 button while D5 is starting up, other times, and mostly when I'm just working in D5 with Vectorworks in the background, Vectorworks just goes away, poof, without any warning. When I'm working on Vectorworks without firing up D5, it rarely if ever crashes. Attached is an image of what I see often in the Task Manager while running D5, don't know if this is related.
Dell Precision 3680, 128GB RAM, i9-14900 processor, NVidia RTX A4000 ada Generation
cheers,
Anthony
@erminio Hi. I still have a similar problem. Could you tell me how you solved it?
The problem has been going on since VW 2025 came out. Vectorworks sync crashes when I  link my VW project to D5. I uninstalled -reinstalled D5 it many times. Most of my questions were answered in the D5 forums, but I can't find an answer in the VW Forum. And I think the problem is caused by VectorWorks2025. Because, when I transfer from Vectorworks 2024, D5 does a normal import and there is no problem. But in the 2025 version VW, it always gives the same error. Everytime VW closes immediately. I am waiting for a response from Vectorworks Team. I hope it will be solved as soon as possible. (and please don't ask me about my software versions. Both my softwares are up to date.)
@JuanP (please check DM)
Thanks,
Sunal.
