SamIWas Posted October 7, 2024 Share Posted October 7, 2024 (edited) Before I post this as a bug/annoyance, maybe it's considered a "feature" and someone can explain why. It's killing me. Every time I go to a viewport and select edit camera position, Vectorowrks insists on rendering the view in what I assume is Fast Renderworks, every time I adjust the camera. I have to make sure to put in Shaded mode, but many times, that freezes the software and I have to force quit. It never did this previously. Is this some new thing? Is there somewhere to choose this or to turn it off? Edited October 7, 2024 by SamIWas Quote Link to comment
markdd Posted October 7, 2024 Share Posted October 7, 2024 If the Viewport has been made using a Camera, then check the Object Information Palette for the Camera Object. There is an option to change the Render Mode. Select Shaded or Wireframe instead. That should do it. Quote Link to comment
SamIWas Posted October 7, 2024 Author Share Posted October 7, 2024 (edited) 1 hour ago, markdd said: If the Viewport has been made using a Camera, then check the Object Information Palette for the Camera Object. There is an option to change the Render Mode. Select Shaded or Wireframe instead. That should do it. They are generally not made using Renderworks cameras. I almost always make them by going into Walkthru mode, setting up my view, then creating a viewport from that angle. Edited October 7, 2024 by SamIWas Quote Link to comment
