Contextural menus don't work in 2025
Many years of using Vectorworks have trained my hand to right-click, move the cursor to the contextual menu item, and release the cursor to execute. This has always worked for me until I started using 2025 and I experienced this issue. Vectorworks Support advised me to click again on the contextual menu (with a LEFT click as Rob notes!) to execute the command - this solved the issue. I thought this changed behaviour was an undocumented new 'feature' but Rob's answer above seems to confirm it is a bug.
  • 1 month later...
Rob,
Thank for confirming the bug and the work around.
I assume there is an update coming soon to fix this and the read only file preview bug. These are serious basic VW functionality Quality Control issues and should be address quickly.
Thank you again for letting us know the work around.
  • 2 weeks later...
I am using Keyboard Maestro all the time and my right-click just works perfectly in 2025, Mac OS 15.1.
The difference I read is:
I richt-click to open the contextual menu, then left-click on the needed action.
When doing a right-click-drag over the appearing contextual menu and release over the needed action, it doesn't work in 2025. In 2024 it did.
I never used the right-click-drag before so I didn't notice this flaw.
  • 3 weeks later...
