Wanted to check and see if anyone else is experiencing this situation.
Since upgrading to v2025 newly created Section-Elevation Lines are not visible in viewports, at least for me. This seems to only occur with newly created sections in v2025. For example, if I open and convert a v2024 file the previously created Section-Elevation Lines show in viewports but if I created a new one, I get the two recently reported dialog warnings, "Error preparing the Vectorworks Vision Plugin" & "A Spotlight license must be present to use Showcase" and the section viewport is created however the marker will not display in other viewports.
"Unlinked" Section-Elevation Lines will display while the "linked" ones do not.
The attached v2025 test file demonstrating the issue.
rWulff
Any ideas for a work-around?
Thank you,
Ron
Section-Elevation Line Test v2025.vwx
0 answers to this question
