Door
How can I make a Node in Marionette with a Script ?
Here is the Scipt.
hTür = vs.WSScript_GetObject()
#Datenbank Tür
record = 'Door CW'
fieldname = 'Space1UUID'
#Datenbank Raum
recordRaum = 'Space'
fieldnamesRaum = ['11_Building','11_Floor','11_Room ID','11_Number']
dataRaum = []
#UUID von Raumnummer 1 auslesen
UUID = vs.GetRField(hTür, record, fieldname)
hRaum = vs.GetObjectByUuid(UUID)
#Die Felder Gebäude, Stockwerk, Wohnungsnummer und Raumnummer auslesen
for field in fieldnamesRaum:
	data = vs.GetRField(hRaum, recordRaum, field)
	dataRaum.append(data)
#Die Felder Gebäude, Stockwerk, Wohnungsnummer und Raumnummer zusammensetzten
raumnummerTür = dataRaum[0] +'.' + dataRaum[1] + dataRaum[2] + '.' + dataRaum[3]
#Resultat zurückgeben
vs.WSScript_SetResStr(raumnummerTür)
My new Friend ChatGPT tried to help me, but it doesn't work 😃
#COMMAND;READONLYREFFILE;[VWLibDef]/Records & IFC\Get Record Field.py;
#Created by [Your Name] on [Date]
@Marionette.NodeDefinition
class Params(metaclass=Marionette.OrderedClass):
    # APPEARANCE
    this = Marionette.Node("Get Room Number from Door")
    this.SetDescription('Returns the room number associated with a door.')
    # Input Ports
    inDoor = Marionette.PortIn(vs.Handle(0), 'hDoor')
    inDoor.SetDescription("The input door object")
    # Output Ports
    roomNumber = Marionette.PortOut('sRoomNumber')
    roomNumber.SetDescription("The room number associated with the door")
    success = Marionette.PortOut('bSuccess')
    success.SetDescription("True if operation was successful, false otherwise")
    # BEHAVIOR
    def RunNode(self):
        # Inputs
        hDoor = self.Params.inDoor.value
        # Database definitions
        recordDoor = 'Door CW'
        fieldUUID = 'Space1UUID'
        recordRoom = 'Space'
        fieldNamesRoom = ['11_Building', '11_Room ID', '11_Number']
        # Initialize output values
        roomNumber = ''
        success = False
        # Get the UUID from the door
        UUID = vs.GetRField(hDoor, recordDoor, fieldUUID)
        if UUID:
            # Get the room object by UUID
            hRoom = vs.GetObjectByUuid(UUID)
            if hRoom:
                # Gather room data
                dataRoom = []
                for field in fieldNamesRoom:
                    data = vs.GetRField(hRoom, recordRoom, field)
                    dataRoom.append(data)
                # Create room number string
                roomNumber = f"{dataRoom[0]}.{dataRoom[1]}.{dataRoom[2]}"
                success = True
            else:
                vs.AlrtDialog("Room not found for UUID: " + UUID)
        else:
            vs.AlrtDialog("UUID not found for the door.")
        # Outputs
        self.Params.roomNumber.value = roomNumber
        self.Params.success.value = success
can someone help me ?
I want to record the Roomnumber in a Database, so can i export the number with the Door in my IFC....
Best regards
