Worksheet Formula to Increment a Record ID
This works just fine in a Spreadsheet type cell, but it will not work in a Database type cell.
If you wanted to increment column A and cell A1 has a value of 1 the formula would be
=A1+1
If you copy that formula and paste it into a range of cells, the row number will automatically increment in each row giving:
=A2+1
=A3+1
etc.
HTH
There is no easy way to use a formula between different database rows. Since the database can be sorted by different columns, it has no real way of knowing what row is above or below. You certainly would not want your objects renumbered just because someone changed the sort order of the database.
If the column has a ='Record'.'Field' type formula, you could select a range of number from a set of spreadsheet cells (in the same or in a different database and then Copy/Paste it into the cells you want to renumber. In VW2025 you can just select the first cell and Paste and it will paste down to match what is on the clipboard.  Previous versions you may have to match the size of the Copy and Paste regions.
HTH.
