It would be useful if floors could adopt the hole forming functionality of roofs. ie. the way in which you can cut holes in roofs by just placing a polygon into the "roof group". Cutting holes in floor slabs would be a lot easier if it could be done the same way.
Another nice feature would be the ability to resize the floor polygon inwards or outwards by a one click method, rather than having to create a new polygon using the offset tool and then deleting the original polygon. This would allow the source polygon to be generated by the walls and then this polygon could be easily resized to get the right relationship to the walls.
The other necessary floor improvement which is required (and has often been mentioned before) is the ability to apply different textures to the top, bottom and side surfaces of the floor slabs.
