Getting references to Objects
Anton3210
I´m fairly new to vectorworks. I´m quiete experienced in programming. Im trying to write some, in my understanding, quite simple and small scribts. It isn`t clear to me neither from Marionette nor from the Python Function References how to get an reference to an Selected Object or to all the object or to any object in your Document. Is it nor intended to write code that works with Information already in the Project or did i just didn't look in the right place?
The concept is called Handles in Vectorscript. And since Python in Vectorworks is really just a wrapper to Vectorscript, the concept applies in Python as well.
In the Vectorscript Function Reference. Sort by Class and look in the Document List Handling section.
vs.FSActLayer will return a handle to the first selected object on the active layer. vs.NextObj/vs.NextSObj/vs.PrevObj/vs.PrevSObj will let you "walk" the object tree.
There are also calls that will return a hand the an object by Name or by Criteria about the object.
Take a look in the Vectorscript and Python sections of the forum for lots of example code.
Or post more about what you need your script to do and you will probably get lots of suggestions on how to approach it.
IMNSHO, Marionette is better for creating object and scripts are better for modifying objects already existing. Especially if you already have some programming experience.
I have not tried, but I believe you can get Hoist date in Vectorscript/Python.
Hoists are just Plugin Objects, so you can use the GetParametricRecord commands to get a handle to the record that contains the hoist data. GetName on that Handle will give you the name of the Record. From there you can use the GetRField and SetRField commands to access the individual fields.
HTH
  • 2 weeks later...
So something like this should give me all Values of the Record of an Hoist object or of any Object that has an ParametricRecord?
test = []
CurrentDatabase = vs.GetParametricRecord(hoist) # 'BrxHoist'
numCurrent = vs.NumFields(CurrentDatabase)
for x in range(1,numCurrent):
   test.append(
       {'name': vs.GetFldName(CurrentDatabase,x),
        'type':vs.GetFldType(CurrentDatabase,x),
        'value':vs.GetRField(hoist,vs.GetName(CurrentDatabase),x)})
But The GetRField returns an empty String whatever doesn't matter wich arguments i give. Any idea what I'm doing wrong?
My Bad, it must be:
test = []
   test.append(
        'value':vs.GetRField(hoist,vs.GetName(CurrentDatabase),vs.GetFldName(CurrentDatabase,x))})
And then it works
