"Lock-In" Rack RU's?
tom-SPL
When entering manufacturer's specs for a rack, the RU count changes after a height is applied to the rack. I would want there to be a way to make it so these measurements are not proportionately linked unless desired.
1 answer to this question
@tom-SPL Yes I can see that might be inconvenient. We have to adjust the parameters so that  overall height = bottom thickness + 44.445mm * RU + top thickness. Preserving the RU value as you ask begs the question of whether to adjust top or bottom or both? But I do see your point.
We will look into this and see if there's a better way to link these parameter values.
Conrad
