Davis Sezuni Posted September 28, 2024 Share Posted September 28, 2024 Hello fellow VWs. I am having an issue with VW's Equipment summary not showing the total number of LED Panels, instead it only lists it as Flat Tile and quantity as 2. since I have 1 Wall and another with a different dimension. The first LED Wall has a total on 90 Panels, and the other has 28 Panel. How do I configure my screen to be able to be identified in Equipment Summary with accurate totals. Quote Link to comment
markdd Posted September 28, 2024 Share Posted September 28, 2024 If you want to generate just a count of Tiles, use a worksheet. If you want to generate an image as well as a count of tiles, a Graphic Legend will do the trick. Alternatively, use a Data Tag on each LED Screen array. Select the LED Screen, run the Create Data Tag command from the Tools menu, and complete the dialog. You will need to search for the Module Total Value. When you click OK, a data tag style will be created displaying the correct value. You can now use the same Data Tag style whenever you need to do this in the future. Quote Link to comment
