pivot-hinge door plug-in
decayny
3 answers to this question
I second archoncad's recommendation
Check out WinDoor 11 available from OzCAD in Sydney.
It will do all you want and much much more:
- Fully editable parametric objects (ie., user controlled parameters).
- Door styles include flush, half glazed, glazed, panelled and louvred, as well as glass doors with square or splayed rails or patch plates. Any door style can be used with any door type.
- Door types include hinged, pivot, sliding, cavity sliding (pocket), multi-track sliding, bi-fold and folding. Any door type can be used with any door style.
- Window styles include fixed glass, fixed sash, awning hung, double hung, sashless double hung, cottage double hung, casement, sliding, louvred and glass block.
- Window types include straight, bay, bow, corner and round.
- Doors and windows can be combined with an almost unlimited range of possibilities.
- Two different styles of glazing bars (muntins) are available for both doors and windows.
- Many different styles of masonry sills can be created as part of the window or door unit.
- Support for brick header courses above door or window openings.
- Extensive control over internal and external trim.
- Sloping, gable and curved heads with user defined radius.
- Door hardware that includes symbol-based user defined objects.
Once you start using it you will hardly use the NNA door and Window PIO's again. About the only thing it doesn't do is overhead doors.
