decayny
Filleting more than one vertex simultaneously
Multi-Fillet - fillet [or chamfer] all vertices of a polyline or rectangle at one time. individual filleted corners could later be edited to adjust radius setting for unique instances.
5 answers to this question
If you use the fillet tool, but just click once on a rectangle, not on two adjacent edges, then it fillets all corners of the rectangle. And when done that way, the fillets stay the same size even if you drag-stretch the rectangle to a different size or shape.
jan,
Great tip re the fillet tool. However, I can't make the same trick work with the chamfer tool. Clicking in the middle of a rectangle converts it to a polygon, but doesn't chamfer the corners!
Perhaps we could request the Chamfer tool function like the Fillet tool.
