Sound Vision on Vectorworks 2025
Regie
  • 3 months later...
  • Administrator
@Mr. Spok
Getting the L-Acoustics Menu in Vectorworks
1. Install the Plug-in: First, ensure you’ve installed the plug-in through the Install Partner Products option. Just go to Help > Install Partner Products in the menu.
2. Restart Vectorworks: Once that’s done, restart Vectorworks.
3. Look for the L-Acoustics Menu; if after restarting, the L-Acoustics menu isn't there, add it manually.
4. Add It Manually (if needed): Go to Tools > Workspaces > Edit Current Workspace, find the L-Acoustics menu, and add it.
That should do the trick! If you run into any issues, contact our technical support team via https://customers.vectorworks.net/support
  • Like 3
  • 6 months later...
On 1/15/2025 at 10:54 AM, JuanP said:
@Mr. Spok
I am on 2025 build 6 and no matter what I do, I cannot get it to show up in the menu bar. I see it under edit workspaces as suggested but nothing is working.
  • 7 months later...
