I have used the drawing label tool before, but for some reason now when I use it it seems stuck to none class visibility. No matter what class I assign it in the object info palette it behaves like the class is none. So I assign it to a different class (sides) but when I hide none class it disappears. I check and it still is assigned sides class, which is visible, but it acts as though it is assigned to none class for visibility.
My old files work perfectly - the drawing label shows up with the class visibility it is assigned, not none, so seems to be happening now with new files. I also tried several different files and the behavior is the same. No matter what class I assign the label to it follows none class visibility.
Using VW 2024 update 7 Spotlight on a Mac. Thanks for any help/suggestions!
Frank Schneider
Frank Schneider
4 answers to this question
