Piotr Rachtan Posted September 20, 2024 Share Posted September 20, 2024 (edited) I'm trying to display label with icon on the Viewpane, based on the below code, I set the path to `16x14-32bpp@72dpi` png file + the@2x file is also accessible (32x28-32bpp@72dpi). // add a single label to this row // The icon.png resolution should be 16 x 14. The developers should provide the large resolution icon 32 x 28 // Otherwise, the default icon will be used. // The text should be from the resource (vwr). labels.push_back( {"Localized Viewpane Label 1", "vwrFolderWithoutExtension/Images/Icon1.png" } ); The above code works as expected for VW2023, but stops working for VW2024, a pop-up appears: What I'm doing wrong? (png files attached) icons.zip Edited September 21, 2024 by Piotr Rachtan Quote Link to comment
