Cage structure modeling
OmerKfir
yes, you can model those in VWX directly, but probably not as easily in c4D.
The one on the right is easy.  Just draw the pattern in 2D as an unrolled surface and use the Deform tool to bend it into a cylinder.
The left one can be done in a similar fashion, but instead of bending it, you can use the Slice tool to cut it into sides of a box and then 3D rotate each side into position.
Either could be done with a texture instead if you are looking for quick and dirty.
Here is one pattern drawn in 2D and then built into the two different shapes using the techniques I mentioned.  Looking at the box with circular cutouts, a better rendition could be created by using spheres instead of extruded circles as the subtraction shape if you wanted something really nice.
