jpkna Posted September 16, 2024 Share Posted September 16, 2024 We are transitioning from 2D to 3D Vectorworks, and I'm working through the process of automatically creating window schedules to match our old ones that were filled in manually. There is a number of standard columns of data in the old schedules that do not have their own data field in the Window/Door object, for example Window Fire Rating, Ironmongery/Hardware information and Specification References. What is the best way to create new data fields? I have identified a few options but would love to know the recommended workflow for this: 1. Fill in some fields manually like before - not ideal. 2. Use the User Fields at the bottom of the Data panel - this seems a good option but I don't know if they can be renamed so is difficult for everyone in the office to remember which is which. It is also not scaleable past 9 fields, which could very easily fill up across multiple projects. 3. Use custom records to add data - this has potential but is also not ideal as it seems it is not added to the style but just the window instance. Some of these seem like a big oversight (fire rating!) and something that a lot of people will need to add to schedules, so is there a recommended way to do it? Quote Link to comment
Tom W. Posted September 16, 2024 Share Posted September 16, 2024 16 minutes ago, jpkna said: 3. Use custom records to add data - this has potential but is also not ideal as it seems it is not added to the style but just the window instance. Right-click on the Window Style in the Resource Manager + select 'Attach Record...'. This adds it to the style + therefore all current + future instances. 1 Quote Link to comment
jpkna Posted September 16, 2024 Author Share Posted September 16, 2024 Also if you edit a cell in the schedule will it update the field in the window object? That would be really helpful Quote Link to comment
Tom W. Posted September 16, 2024 Share Posted September 16, 2024 18 minutes ago, jpkna said: Also if you edit a cell in the schedule will it update the field in the window object? That would be really helpful Yes, if the parameter is by instance 1 Quote Link to comment
shorter Posted September 16, 2024 Share Posted September 16, 2024 Recommend you do this via IFC data mapping, and create a custom pset, and a data sheet and schedule from that, along with integral attributes from the window itself. This way you can also attach the same data set to a symbol of window, and schedule from both in the same way. Quote Link to comment
jpkna Posted September 23, 2024 Author Share Posted September 23, 2024 (edited) On 9/16/2024 at 12:29 PM, shorter said: Recommend you do this via IFC data mapping, and create a custom pset, and a data sheet and schedule from that, along with integral attributes from the window itself. This way you can also attach the same data set to a symbol of window, and schedule from both in the same way. I have looked into this and it seems to work really well - I have a Window Schedule Data Sheet set up with all the fields required for the Window Schedule (some are from a record format, some are reading from the Window Style attributes). However, by editing the data in the Data Sheet I am able to change the window attributes that are "By Style" and therefore shouldn't be able to be changed? e.g. I can select a window in the model, and in the Data tab I can type a new window ID Label. Then in the window attributes this window instance has a different ID Label to others, even though the ID Label is set to By Style. When I change something in the window style it overwrites the new ID label and sets it back to how it was. Have I set it up incorrectly or is this somehow intended behaviour? I can see this actually being useful if I understood it more: we often put "As Existing" in various fields (including S.O. dimensions) in manual window schedules, and I am trying to work out a way to have that option in the automatic schedules. Edited September 23, 2024 by jpkna fixing grammar Quote Link to comment
shorter Posted September 24, 2024 Share Posted September 24, 2024 Yes., That's to be expected. Style parameters rule over instance parameters, or use the DM to refer to another value using =firstnonempty or such like. Otherwise, you have to liberate the parameter you want to be related to the instance. Quote Link to comment
jpkna Posted October 4, 2024 Author Share Posted October 4, 2024 On 9/24/2024 at 7:09 PM, shorter said: Yes., That's to be expected I think I didn't explain very well: I am able to edit Style parameters by editing the Datasheet in the Data tab for an individual instance. So that one instance now has a different parameter value to other instances of the same Style, which should be impossible as it is set to By Style. It is reset to the Style value if I update the Style by editing and saving (although I change nothing). Quote Link to comment
Stefan Bender Posted October 7, 2024 Share Posted October 7, 2024 Looks like a bug in the worksheet function that shouldn't allow you to edit values that are by style. But if something (like editing the style) triggers regeneration of the instances, the instances should be fixed (ie, the values should be replaced by the values of the style). Quote Link to comment
