In the 'other' BIM software, there are objects that are the 'descendants' of a common 'ancestor', such that if you change properties in the common ancestor or 'parent' those properties change in all descendants.
For example:
Door Type A, comes in 5 sizes, and different leaf arrangements, i.e. single, double, leaf and a half, and different fire ratings, leading to a number or Door Styles.
A number of properties of Door Types are identical in all 5 size variants. Same material, same frame size. They only vary in size, leaf, and fire rating. These parameters are locked down to stop non-variant sizes being used and under the current behaviour, this means we have many Door Styles.
So what we want, is for Vectorworks to introduce a 'Parent' style, for all 'Descendant' styles so that when there are many descendant styles based on the parent style, changing someting in the parent style changes the parameters of the descendent styles, rather than us having to go into each descendant style and change it manually.
This is what happens in the 'other' software using 'parents' and 'children' in it's organisational grouping of objects.
shorter
For example:
Edited by shorterLink to comment
6 answers to this question
