1) I wish I could change the Viewport Crop pen and fill attributes both from outside and inside the crop editing mode. As it is now one can change the Viewport border/pen only when editing the Crop Object, and the background/fill only when outside it
2) I wish that when the Convert to Lines or Convert Copy to Lines command is applied to a viewport the resulting lines were put inside the annotation part of the Viewport thus enabling one to dimension them correctly. As it is now the results are scaled to retain size appearence at the 1:1 Sheet Layer.
3) I wish that when inapropriate objects are selected in a Sheet Layer while creating a new Viewport they should simply be ignored. Otherwise, make the command unavailable if there is such a selection.
4) I wish that the last scale value used should be proposed when creating a new Viewport directly in a Sheet Layer.
5) I wish that when double-clicking a viewport, keyboard modifier keys would take one directly to the Annotation, Crop or Design Layer editing behavior. Something like: Shift+double-click -> Annotation; Mac-Command/PC-Alt+double-click->Crop; Both modifiers together would get one the first visible Design Layer or perhaps bring the Viewport editing panel with the third radio button already selected.
Off Topic P.S.: Similar modifier key shortcuts could be added to Extrude Along Path objects and Path PIOs.
Off Topic P.P.S.: I wish modifier keys would toggle class and layer visibility when choosing them from the active class & activel layer menus.
[ 11-06-2004, 12:51 PM: Message edited by: Alexandre B A Villares ]
Alexandre Villares
2 answers to this question
