VW2025 Error dialog when making View Ports
Dubman
Each time I make a rectangle over a Design Layer drawing to make a Viewport on a Sheet Layer I'm getting "Error preparing the Vectorworks Vision Plugin" I'm not using any Vision Plugin only a Viewport. After clicking on the OK button the Error Dialog box disappears & the Create Viewport box opens. Not sure the Vision Plugin is or why it is now tied to the Create Viewport command.
16 answers to this question
I was just going to post that there was an error message when making Viewports. See attached screenshot. I am using VW Architect.
I also experienced four hard crashes (as in VW completely closed and the model did not save) in the first fifteen minutes of playing around with VW2025, just playing around with the 2 point perspective and new navigation widget.  I selected a fairly easy model, with not much in the way of viewports or annotations.   Not atypical for a SP-0 release.
That said, the floor reshape bug that plagued VW 2024 appears to have been fixed in VW 2025.
51 minutes ago, klinzey said:
@DubmanWhich product do you have licensed? Fundamentals, Architect, Landmark, Spotlight or Designer?
I'm using VW Architect & usually draw a rectangle & then right mouse click to select Create Viewport. I did migrate everything from VW2024 even though I've never added or used Plug-Ins not knowing if that what is causing this. Never seen it before in previous version. One thing I'm really liking VW2025 for is my Smart Curser Cues are staying on.
I did what the link rDesign mentioned I after rebooting my computer VW2025 is still giving me the error dialog. I might trying to reinstall VW2025 & not migrate any setting from VW2024 & see what happens.
Thanks for all of the suggestion!
I can confirm the same problem with VW Architect clean install (no migration from 2024) and Mac restart.  In case it helps troubleshooting, I also had Vision warnings pop up when I installed VW 2025 (submitted report to tech support via web form).  I deleted 2025 and reinstalled after the Installer app was updated (other thread on Forum).
Edited by E|FA
I am having similar problem with crashes or spinning wheel of death when I try to create a viewport from a rectangle. I'm not getting those plugin messages. I'm using spotlight.
I tried a restart and a reinstall. Neither fixed it.
I really hope this update comes soon and fixes the issue. I have a lot of drawings that I really need to send!
