VS:SetComponentName doesn't change componentname
I try to check componentnames in one of our projects and, due to the fact, that in that project there's a huge number of wallstyles,...
I try to solve it with a script.
howver VS:SetComponentName doesn't change  the componentnames inside that file.
(as you can see in the testfile)
def schichtkorrektur(hndl):
	wallname = vs.GetWallStyle(hndl)
	vs.AlrtDialog(vs.Concat('Wandstilname: ',wallname))
	for i in range(1,10):
		componentname = vs.GetComponentName(hndl,i)
		cnnameeins = vs.SubString(componentname,'-',1)
		cnnamezwei = vs.SubString(componentname,'-',2)
		cnnamedrei = vs.SubString(componentname,'-',3)
		cnmat = vs.SubString(componentname,'-',4)
		cnnamefuenf = vs.SubString(componentname,'-',5)
		cnnamesechs = vs.SubString(componentname,'-',6)
		vs.AlrtDialog(vs.Concat(cnnameeins,'-',cnnamezwei,'-',cnnamedrei,'-',cnmat,'-',cnnamefuenf,'-',cnnamesechs))
		vs.SetComponentName(hndl, i, (vs.Concat(cnnameeins,'-',cnnamezwei,'-',cnnamedrei,'-',cnmat,'-',cnnamefuenf,'-',cnnamesechs)))
#		vs.SetComponentName(hndl, i, (vs.Concat('MOIN')))
vs.ForEachObject(schichtkorrektur,('T=WALL'))
#vs.ForEachObject(schichtkorrektur,'((T=WALL) & (WST=WA-I-NTR-GK*))')
he doesn't even replace the componentname with "MOIN" 🤨
any ideas?
WANDSKRIPT.zip
now i did reduce the code to essential problem:
def changewallcomp(hndl):
vs.ForEachObject(changewallcomp,('T=WALL'))
theorically now all wall components should be named 'MOIN' after having executed that script. Unfortunately, that doesn't work.
Did I misunderstand the "SetComponentName" function?
If so i would not just loop the walls in drawing and changing the same stile hundreds of times. I would get the walls and collect the used style names. Then i would eliminate duplicate names and loop the style names. Or collect the Resources directly.
Beside that, i would not change object swhich i collect with "ForEachObject" directly in the "ForEachObject" callback function. I would use "ForEachObject" always as a read only manipulation.
something like this:
wall_style_names = []
def get_objects(h):
	wall_style_name = vs.GetWallStyle(h)
	'''hinzufügen, falls nicht schon in der Liste'''
	wall_style_names.append(wall_style_name) if wall_style_name not in wall_style_names else None
vs.ForEachObject(h,('T=WALL'))
for wall_style_name in wall_style_names:
  	wall_style_handle = vs.GetObject(wall_style_name)
	'''security to be sure just manipulating wall styles'''
    if vs.GetTypeN(wall_style_handle) == 127:
		#Do your component renaming code here
  • Like 3
