Cory W. Posted September 5, 2024 Share Posted September 5, 2024 (edited) I'm sure it's user error, but I struggle with the working plane tool. In this example I have the working plane set to an exterior wall. I drafted a 3D polygon as a guide for additional work. I can't see it, but not head-on (Left View)... even if I turn the textures off. I can sorta work with it in ISO, but should I be able to see a 3D polygon on a wall in a head-on view? ALIGN-WALL-3D POLY.vwx Edited September 5, 2024 by CW2020 Quote Link to comment
cberg Posted September 5, 2024 Share Posted September 5, 2024 Try making the 2D linework a 2D Polyline or 2D Polygon. 1 Quote Link to comment
Tom W. Posted September 5, 2024 Share Posted September 5, 2024 I always just draw Lines for this kind of thing - never 3D Polys - and convert them to Guides for easy hiding + deletion. Activate Auto Plane (\ key) + just draw directly on the object. 2 Quote Link to comment
cberg Posted September 5, 2024 Share Posted September 5, 2024 I think coplanar 3D objects are intended to visually merge in Shaded Render mode. If you absolutely must use a 3D polygon, try using hidden line rendering. 1 Quote Link to comment
Cory W. Posted September 5, 2024 Author Share Posted September 5, 2024 29 minutes ago, Tom W. said: Though not as clean, that's sorta been my approach. Though I wasn't mindful that the 2d lines are on the same plane as the object, which all you to study it in 3D. Thanks Quote Link to comment
line-weight Posted September 5, 2024 Share Posted September 5, 2024 The x-ray feature (press B) is very handy in this kind of situation! Like others, if I want to draw guidelines on a working plane, I tend to use 2d objects. Partly because they are more visible, partly because you can be quite sure they will actually be on the working plane. If you draw a 3d polygon it's possible to inadvertently snap to something that's not on the working plane. 2 Quote Link to comment
Cory W. Posted September 5, 2024 Author Share Posted September 5, 2024 I appreciate the input cberg. I only recently made the push to model projects in 3D when possible. It's very intuitive, just lots to learn... no different than 2D I guess. Quote Link to comment
Cory W. Posted September 5, 2024 Author Share Posted September 5, 2024 Ya know line-weight, I just recently inquired about that tool. Now I need to put it into practice. I'm realizing a flaw with my modeling has been rarely using working planes. But lucky to drop that bad habit sorta early on with modeling. Quote Link to comment
Tom W. Posted September 5, 2024 Share Posted September 5, 2024 For me being able to easily get rid of the guide lines afterwards is just as important as creating them in the first place, hence I like to convert them to Guides - but I think I'm the only one! I have the Guide commands on my right-click menu to speed it up. It can be a real pain trying to select + delete lines afterwards + easy to forget about them completely. 'Delete All Guides' solves that. Same with Loci. These are even harder to find/select/delete. So I have a script that does this automatically for me too. But this is getting away from the subject sorry... 1 Quote Link to comment
Cory W. Posted September 5, 2024 Author Share Posted September 5, 2024 Good suggestion. If I explored using Guides over the years it's a forgotten skill. But I'm gonna try incorporating them into my drafting. Quote Link to comment
Tom W. Posted September 5, 2024 Share Posted September 5, 2024 Cool. Then there'll be two of us using them 😀 Quote Link to comment
line-weight Posted September 5, 2024 Share Posted September 5, 2024 I should start using them too. Quote Link to comment
