Showing a climbing plant wall?
Hi Team,
Using latest version of VW Landmark and looking at options to show climbing plants on a wall/screen, or green wall in 3D.
The options I can see:
- The plug in Greenscreens of varying sizes which are quite artificial looking
- Use one of the 3 or 4 climber options in the Resource Manager
- Use the vertical wall prop symbol
What are the next steps? Would I need to import my own image and turn it into an image/texture?
Thanks
4 hours ago, Marcus bLD said:
Thanks, yeah it looks like there's about 10 or so leaves and flowers if I search Foliage, but nothing like what appeared in that previous forum post you shared.
Actually rereading your post did you actually find the Foliage Tool?
I meant search Vectorworks not search the Resource Manager.
https://app-help.vectorworks.net/2024/eng/VW2024_Guide/Plants2/Adding_foliage.htm?rhsearch=foliage tool&rhhlterm=foliage tool tools
8 hours ago, Marcus bLD said:
That looks pretty useful. Where do I find the foliage tool?
I just saw that you said you have Landmark — so you should have the Foliage tool located in the Visualization tab.
Edited by rDesign
Thanks Tom, yes correct. I searched Vectorworks. In the RM it also lists the same items as in the Visualization tool.
11 minutes ago, Marcus bLD said:
Thanks, have opened that and it is the same list of flowers/leaves as screenshot above.
 That Toolset you posted was of the Site Planning toolset - I don't have Landmark or Designer, but according to the help file page that TomW posted, you need to look in the Visualization toolset for the Foliage tool.
ScreenShot2024-09-06at3_13_53PM.jpg.fcd20b9474e91a3a3383e00fbe8bb5d2.jpgScreenShot2024-09-06at3_18_51PM.jpg.3833dd92e2ab071fc079494766614991.jpg
Edited by rDesign
Yes correct, the Visualization Tool. The same leaves and flowers I can select in there are also in the RM - it's the same database. Question: do you have more than say 10 leaves and 10 flowers in yours? Maybe I am missing something?
Cheers
Cheers
Does the Foliage tool not work for you, or are you just wanting / needing more leaves and flowers than what you are seeing? As TomW said --
On 9/5/2024 at 2:49 AM, Tom W. said:
You can create your own leaf + flower symbols.
The wisteria leaf + flower symbols I was using in that post came from a @Tony Kostreski file that's floating about somewhere...
Beyond that - someone else with Landmark (or Design Series) will have to help further -- as I only have Architect and don't have access to the Foliage tool at all.
Cheers
Have you actually created a Foliage object yet? How do you know that the available choice of symbols is inadequate until you have played around with the tool?
Thanks everyone, it sounds like I need to play around with this foliage tool more. I was basing it off the link at the start of this thread which showed a great wall climber, however it appears this may have been a custom creation using the foliage tool.. whereas i had assume it was like a plug in type object.
Objects created with the Foliage Tool are Plug-in Objects. But I think you mean you're looking for a readymade symbol. To do this you need to create a Foliage object first then save it as a symbol + check the 'Convert to plug-in object' option. The configuration you want for a wall climber is 'Linear'.
You are always so helpful mate. Wish me luck!
Cheers
