Change a Weight to KG from g?
17 minutes ago, Chris J Clarke said:
I looked in the record for the Truss, and it looks to be in KG there, so I'm not sure why the truss.totalweight entry is reporting in grams?
Are you document units set to grams rather than kilos? See File > Document Settings > Units... > Structural
31 minutes ago, markdd said:
The data in the Truss Record is not dynamic and will never change. However, the weight field in the Truss Object can be updated whenever you like. It's all about choices!
Thanks, I'll stick with what I have for now for the truss. I'd like to keep the installed truss weight seperate from the weight of it plus the lights etc anyway. So the fixed number is good for the spreadsheet I made for the truss alone...
I'm trying to make one for the lightis now, but it's not working. I'm so confused about which entries to use in the criteria. It doesn't make sense to me. I've attched an image of the fields I've tried. The headers in blue show the record entries I've tried to get it to work. LightInfoRecord.Weight does show something, but it's in Pounds. If I click on the light, it shows me the weight in the OIP in kg. I would think that then just pointing the worksheet to the Lighting Device Record would do it, but it won't. I've got a graphic legend to show it, but the params I use to make that work aren't available for the worksheet.,
Edited by Chris J Clarke
