Chegs77 Posted March 14, 2002 Share Posted March 14, 2002 Using the curtain tool, I've inserted borders, and given them appropriate heights and lengths. This is all done in Top/Plan View. When I want to view things in 3D, these borders dissapear. As long as I'm in top/plan view I can see them, but any other view does not show them. I also have masking, and that is working just fine in all views. What should I do so that I can view the borders in all views? Catherine Hegdale Quote Link to comment
kmoore1 Posted March 14, 2002 Share Posted March 14, 2002 quote: Originally posted by Chegs77: Using the curtain tool, I've inserted borders, and given them appropriate heights and lengths. This is all done in Top/Plan View. When I want to view things in 3D, these borders dissapear. As long as I'm in top/plan view I can see them, but any other view does not show them. I also have masking, and that is working just fine in all views. What should I do so that I can view the borders in all views?Catherine Hegdale There is a bug in the VectorWorks that prevents the curtain's 3-d geometry from drawing when it is extremely long. If you reduce your 3-d conversion resolution or change the resolution parameter for the curtain to a lower number this might get the curtain to draw. If not then draw the border as a couple of shorter sections of curtain. Sorry for the inconvienance. This is on the buglist and we hope to address the issue in the next major release of SpotLight. Quote Link to comment
