2025 - Room Finishes - New Feature Video
JuanP
  • JuanP pinned this topic
2 hours ago, Sky said:
I wish this would also apply the finish to walls
I also always expected this as a way to control the 3D Model, also for Visualization purposes.
(Since years I propagate that we need to separate structural from finishing components in PIOs
to not die in multitudes of Wall and Slab Styles. E.g. for a structural part of a Wall that runs
through external Wall to internal Wall environments and gets different finishes for different
touching rooms and such)
If I got that right the new feature is just a a Tool for Documentation and maybe Calculations (?)
Is this all just documentation?
That is what I understand from the video.
Need to be able to assign real world materials to the rooms
and have that report.
In other words, baseboard, window and door trim, chair rail (if any), crown moulding (if any),
carpet, vinyl, tile, hardwood, etc.. all show in 3D, and report.
Am I missing something here?
I had the same reaction to the video -- it looks like you manually assign a percentage of coverage for each wall finish. Which is not very useful for reporting, as it is not calculating the actual wall coverage take-offs.
@JuanPNot my intention to hijack new features! I'm sure it'll be great!
@rDesign I think the space function will cover the takeoffs, and the tagging of the walls seems pretty neat. The only thing it won't be able to do is translate that to a live view of the finishes. If only a material feature to wall finishes (as it is incorporated in wall styles to deviate from the style to lock on to other levels in a story) can be incorporated into walls. If that will be the case, using the GetSpaceNameForObj and GetSpaceNumberForObj could be useful in discerning the finishes of the wall types in them. I've used the hacked method of extracting polygons from the layers and using getspacenameofobj to isolate the object records in that space, not limited to finsihes. It's very useful for code implementation, lighting fixtures, switches, floor and ceiling finishes etc. )
But it can be like a shotgun sometimes. Still, i can't complain, major time saver.
How would you extract wall finish surface area from a Space? I can see that you could calculate the total wall area for a Space by multiplying the perimeter by the height but I don't see a way to separate out the individual wall segments if there are different finishes on each. And I can't see any way to report on the Coverage % but perhaps both these things are to come.
Can you explain a bit more what you do here + what the results are...?
Perhaps @Samuel Derenboim can shed some light on this but as far as I can see I don't think you'd look to use Room Finishes to report quantities. It's more to generate a room-by-room schedule of finishes. Materials/Components are the way to go for reporting material/product quantities but you can't unfortunately generate room finish schedules from Materials because Spaces + Walls/Slabs/Roofs can't 'talk' to each other. There has been discussion elsewhere about this: somehow being able to link a Wall Component to the Space it adjoins + return that info in a report. I don't know whether Samuel is saying above he's found a clever way of achieving this... Hope so!
  • Like 3
In terms of getting GetSpaceNameForObj and GetSpaceNumberForObj you need to extract geometry and apply a material to the geometry (at least for walls). For this i use the face extract tool in the 3d modeling toolbox. Then i can use those functions to get the materials of every polygon / nurbs object in that space. I.e. Isolate the polygons by space using the functions above - and then extract the materials of those objects in them. Those nurbs and polygon objects already have geometry, dimensions, etc... when you extract it. just so long as it has a record
I also have a design layer for ceilings, FF&E, Floor plan. So limiting it to those layers makes it even easier.
teeeechnically, you can get a little creative by extracting the component number when getting walls using the getspacenameforobj function. However, if space 1 and space 2 are both adjacent to wall 1, space 1 and space 2 will not know which side they're touching. But of the object is entirely in the space, you can do wonders when extracting information from them.
First step though is to get the brilliant programmers from VW to allow materials to change in wall styles on an individual basis (a bit like setting the height parameters that deviate from the original levels they're assigned to in the wall style) in order to do this. THEN maybe integrate it to the space finishes function they implemented into this version of VW.
Also the new specification tool, LIFE SAVER!
Ah ok. Thanks. I am wondering whether this is less work than assigning the finish Materials to the Wall Components (in order to report quantities) then adding them as Room Finishes as a separate operation in order to generate finish schedules...?
I'm presumably the NURBS/Polys are purely for reporting purposes + get turned off in VPs?
yea, unless you need to do elevations to tag them and visualize the colors of the walls, or finishes. It is intended for both callouts and walkthroughs. Sometimes you will do a walk through and say - hey, that wall color is wrong...then you assign a different paint color material on the fly. you do that, all schedules change, and you save the office from making a mistake. lol
Since you cannot assign unique materials to 1 wall style (at least not that i know of now) it doesnt really matter. The polygons and nurbs extraction technique are for strictly finishes. The materials in a wall i.e. gyp bd, sheathing, plaster, etc... would be noted for construction, sound attenuation, r value and / or fire rating characteristics (maybe other elements like weight could be useful, just haven't implemented that yet either). I just downloaded VW 2025, so i'm still exploring the finishing options. hopefully i can get back with some info later 😉
So apparently it does extract surface info from the space which is great! The only issue is that I don't know yet how to get the information to be accurate to the inside of the walls. See screenshot below
Can you post a file or a screenshot of the tag formulas? Thanks!
@Tom W.
This is the function in the tag. VW did an awesome job allowing for worksheet formulas to be used in tags. So i tinkered, this is the surface area function for the wall.
First tag the walls.
Make sure to check the button
Then go into the tag layout - this is for the surface area...
And finally you should get this. The areas look correct now. dimension of the space is 14'5xx17'1x9'
also, pleaaaase tag subparts work with walls!!!! Awesome addition!
Edited by Samuel Derenboim
1 minute ago, Samuel Derenboim said:
@Tom W.
Yep found it thank you!
Without removing the coordination issue of having to model/specify twice then can we call it what it is and say this just isn’t a BIM feature. Even if useful. it fails the only test of BIM
  • Confused 1
  • 7 months later...
Hi
Just starting experimenting with this feature and while the video at the top is useful, I do not really think it is an instructional video. Are there any videos which provide more detailed instructions?
I have the room spaces created, and I have managed to create a simple wall finishes schedule in the Room Finishes Manager, which I can then use to apply finishes to the individual walls using the Assign Room Finish option.
However, when I use the Tag Room Finishes, it tags all the walls, not just the side of the Space Object I select. For example, in the first 30 seconds it shows tagging the individual walls within a room, but does not explain how to do that.
Any help would be appreciated.
Kind regards
Mike
Edited by Michael Siggers
