Standing seam cladding rendering
Hello everyone,
I'd like to apply a texture (to which I've applied a relief using a black and white image) of standing seam cladding.
But when I do this and activate the relief, the standing seams come out as I want them to but the flat part of the cladding sinks into the wall.
I'd like only the standing seams to come out without altering the flat part of the cladding.
I've tried to create my displacement map in Photoshop by tracing only the standing seams and exporting it as a png (without background), but nothing works.
Is there a solution (other than geometrically shaping my cladding as I need to work quickly and placing a texture is much quicker once it's been properly sized and saved)?
Thanks for your help!
I don't have time to test this right now but you might try making your flat metal 50% gray and the standing seams, white.
I feel like there was a "feature" where VW displacement maps allow positive and negative displacement.
Update: verified.
The image on the left uses a displacement from 50% gray to white, all displacement is above the top plane of the extrude.
The image on the right uses the same displacement map but is mapped from black to white. Values darker than 50% gray recede into the surface of the extrude.
Edited by BartHays
  • Like 3
Without seeing images, I'd suspect that how you made your displacement map is the issue. It sounds like you only made a texture with ribs (white?) and nothing for the panels (no background).
See the attached sample of a displacement map -- it may be more 'corrugated' than the 'standing seam' you're looking for -- but it should give you the idea. I wouldn't have the image as black and white as you describe, but shades of grey. Save it as a greyscale PNG.
Edited by rDesign
@Jonathan Pickup - looking at the screenshot you posted (highlighted section below) it looks like the ribs are receding into the surface, which is the opposite of standing seam.
Correct me if I’m wrong, but I believe in a proper displacement map — the white parts project from the surface, while the black parts recede into the surface (opposite of what you described).
The user manual should really offer more guidance on these types of things than it does. It only says what a displacement map can do, but does not say how to properly create or use one.
Edited by rDesign
Maybe a different approach.... The AEC Roof Framer tool is an alternate way to model standing seam roof.  I find playing around with RW textures somewhat hit or miss, and the results usually look a little flatter than I would like.  Set the framing to .25" x 1" (6mm x 25mm) and move to the top of the roof face.
  • Like 3
thank you, these are exactly the settings I'm looking for!
However, where is the % displacement setting?
I can find a value but not in %
that's it.
But what's the right level of grey so that it doesn't go into the surface?
1 hour ago, Theo D said:
that's it.
I used an image editor, to create the bump map, fill an area with 50% grey, and then create the vertical "bars" in pure white.
for proper scaling, imagine that the Texture is 24" square (or some other easy to use real-world size) and build the standing seams at the correct width and separation.
In Vectorworks, create a texture, use whatever you need  for the Color, and set the texture size to  24" ( or to fit your image)
Use the new image as a bump map, and set Displacement to the height of your seams.
NOTE: per @Jonathan Pickup when I did this, the Image preview in the Texture dialog showed the displacement in reverse, however, the rendering came out correctly, I'm not 100% sure what is going on here,(but it can be flipped by inverting the bump image(see arrow) depending on your results)
  • Like 3
I think the RW texture preview with the Plane Object Type is incorrectly showing the backside of the planar surface -- because when you use a Sphere or Cube instead of a Plane for the preview Object Type, you get the 'ribs' pointing the correct direction.
You should not invert the bump map based on what you see in the preview because that would then have the ribs receding into the surface.
sphere.jpg.27cf450262b2eec7c01a4bc54347b434.jpgcube.jpg.fb535e4bf520fe59ee3c3db15733f63e.jpgplane.jpg.377e6f09cd73de8283fa1976daaadb53.jpg
These are all the same displacement texture settings, just different preview object types. The first two look correct, but the Plane looks incorrect, but it is not.
Attached is the displacement map I made for this texture and a close up of the viewport. [Displacement maps really do slow down the rendering speed, reminds me why I use them so rarely].
ribs.jpg.e7772bc009133065e5a71812a9271eea.jpgStanding-Seam_DISP.thumb.png.c6e8013f374546b2f228a1ec2242b2ba.png
  • Like 4
@Dave Donley - do you know why in the RW Texture Preview when using a Plane Object type and a Displacement Map, it appears that the preview is showing the backside of the preview Plane as the Displacement is inverted? (see THIS post). The Displacement appears correctly when switching to a Sphere or Cube Object Type preview. Perhaps the Normals on the Plane object are reversed?
I don't know if it has always been this way, but this is how it appears in Vw2024 -- and it feels like a bug. Thanks.
It's been that way for as long as I've been using the program, 2017ish.  I asked the same question a couple of times and got a few different answers.
Comically, several in tech support said I built my displacement map incorrectly and that Black was up and white was down, LOL.
I don't think they care to fix these idiosyncrasies, they seem to persist forever.
  • Like 3
  • Sad 1
Thank you all very much,
I needed to set up my relief maps better and understand the principle behind them better!
Now, another tuning question no doubt: do you know why my standing seam texture, correctly set up, has graphical bugs when I render in the viewport (in optimal rendering)?
Edited by Theo D
14 hours ago, BartHays said:
Can you post the maps? or a VW file with just that texture?
Here's my bump card.
I just used a solid colour for the colour, no card.
(the part with the graphics bug is in a shadow area, could that be where it came from?)
Edited by Theo D
Hmm,
The Map looks ok, I tried crushing the levels in PS, looking for irregularities but it looks fine.
My next guess would be that the Displacement mapping in VW is working with low-res geometry.
you might try upping the Displacement Quality.
IF you can't find the error, you might be better off just modeling the standing seams in 3D.
29 minutes ago, BartHays said:
Hmm,
I've already maximised the quality of the relief and the rendering style...
I don't know what the problem is
