Feature Request: 1/3 & 1/4 Rack Width Options for ConnectCAD Devices?
btgroves
Hi @btgroves
This has come up before and I will certainly consider it. Here's the current rational for what it's worth. Half-rack gear is drawn with mounting lugs left or right depending on where the equipment is in relation to the center-line of the rack. 1/3 rack and 1/4 rack gear would have to also calculate the middle cases. All this has more to do with history than anything else. I created 1/2 rack gear because most broadcast CCU's were that size and came with a side-by-side mounting kit (annoyingly a separate order item...) comprising 2 ears and bolts to stick 2 CCU's together.
Since then we have created the Rack Frame object that can be configured to accommodate 3 or 4 across. And now we also have the rack tray version of this object that is visually less obtrusive. So I do ask myself if we haven't basically got this covered. You are going to need some mounting hardware for these guys aren't you?
Your thoughts?
Conrad
  • 3 weeks later...
@Conrad Preen I will admit I wasn't as educated on these options for using a "Rack Frame" device, I've spent some time working with this, I do realize this is not considered an "Equipment Item" this is a primary reason I was requesting the options in the HeightRU field.  We have a few reports that run on Equipment Item Records and Sort by Equipment Rack/Drop Point Records, since these Rack Frame devices they don't show up in our custom reports but we certainly could adjust the criteria to also find these items.
Helpful information, thank you for the suggestions!
Edited by btgroves
