Francois Levy
3d locus (in)visibility in rendered mode
3D loci (often artifacts of PIOs like fireplaces) are visible in my renderings. While exporting the rendering as an image file will get rid of them, often a screen capture will do for a rendering export. Having 3D loci invisible in rendered views (even if as a preference similar to light objects') would be much appreciated.
4 answers to this question
Even more annoying when you are trying to show a client an OpenGL rendered model on screen. Every time you stop rotating all these 3D loci 'jump' into prominence.
If they had a class of their own they could be made invisible except when needed. it could be argued that for most PIO's they would hardly ever need to be visible.
quote:
Originally posted by Kaare Baekgaard:
By the way: It would be nice, if I were able to replace 3D loci with symbols
Not quite sure if this will work but give it a go. It is a generic utility I have used in 2D drafting for years; just added support (?) for 3D symbols, but did not test or even check the syntax.
code:
PROCEDURE sel2syms; { ? Petri Sakkinen 1998-2004 }
{ This macro replaces selected objects on the active layer with instances of the active symbol }
VAR
i, n, objType : INTEGER;
x, y, z, a : REAL;
xi, yi, zi, ai: ARRAY[1..1000] OF REAL;
theSymbol : STRING;
obHd : HANDLE;
BEGIN
theSymbol := GETSDNAME(ACTSYMDEF);
IF (theSymbol > '') THEN BEGIN
obHd := FSACTLAYER;
i := 0;
WHILE obHd <> NIL DO BEGIN
i := i+1;
x := 0; y := 0; a := 0; z := 0;
objType := GETTYPE(obHd);
CASE objType OF
9 : GETLOCUS3D(obHd, x, y, z); { found a 3D locus }
15 : BEGIN { found a symbol }
GETSYMLOC3D(obHd, x, y, z);
a := GETSYMROT(obHd);
END;
17 : GETLOCPT(obHd, x, y); { found a 2D locus }
OTHERWISE HCENTER(obHd, x, y); { found something else }
END; { case }
xi
:= x; yi
:= y; zi
:= z; ai
:= a;
obHd := NEXTSOBJ(obHd);
END;
IF YNDIALOG('Delete selected objects?') THEN DELETEOBJS;
FOR n := 1 TO i DO BEGIN
SYMBOL(theSymbol, xi[n], yi[n], ai[n]);
IF z <> 0 THEN MOVE3DOBJ(LNEWOBJ, 0, 0, zi[n]);
END;
END
ELSE ALRTDIALOG('You must have an active symbol');
END;
RUN(sel2syms);
Petri Sakkinen
panta rhei information technology
19/125 Oxford Street Collingwood VIC 3066
Australia
[/code]
Made a couple of small corrections. Hmm - should I even test it?
Right - seems to work.
[ 10-08-2004, 07:09 PM: Message edited by: Petri ]
