Referencing dwg sections
fips
Hi, I didn't use VW since v2017 and I may need some help to get back to speed.
Back then I used to import dwgs and rotate them in my file. I assumed references would work better nowadays.
Assume you get section cuts from an architect and you want to design your stage in 3d.
How do you guys do that? Import all references into a .vwx, orient them and then reference this .vwx?
So far I learned painfully, that I can't 3d rotate dwg references :(
I also miss a option that imports dwgs centered on the internal origin without messing with my user orign.
Thanks, Philipp
