Drawing 3D polygons in 3D view and extrude
One of the things I do all the time in FormZ is draw shapes--rectangles, circles, etc.-- on the X,Y plane while in a 3D view, then extruding them in the Z direction while in the same 3D view3. This is very handy in situations when you can only see what you are doing while in a 3D view. I can draw a 2D shape on any 2D plane and extrude in the third dimension. Is there a way to do this in Vectorworks 2024?
I have no problem drawing 3D rectangles, but I don't see a way to keep the angles at 90 degrees. It is out of character for a Vectorworks tool to be so free-form. It is also hard to type in the length of the sides that are not snapping to something. Lastly, once created, there is no way to extrude the 3D polygon you have created. The Extrude tool does not work (it should) and the Push-Pull tool only works sporadically (mostly not at all). To be honest, I don't see what the 3D polygon tool is for since "2D" polygons are already 3D.
In short, what I want is to be able to draw a 3D rectangle (aka, a polygon with four sides and four 90-degree angles) with one of the rectangle tools without having to snap to anything. I want to do this while in a 3D view isographic or perspective. I then want to extrude it in the dimension in which it was not created. I hope that makes sense. I'm showing two images from a FormZ file to help explain what I'd like to do in Vectorworks. Is it possible? I have not been able to find a tutorial on this.
Thanks
MH Brown
Thanks for the tip. No, I start with the 3D poly, but it seems like the 2D polys are actually 3D (when you fly around over them they are clearly 3D.) It seems intuitive that a 3D polygon would be the starting point when in a 3D view. When I try to draw a 2D rectangle from an isometric view, it does not draw on the X,Y plane. It draws it in a somewhat random tilt. If you look in plan view, they are crazy non-rectangular polygons. The shapes in the attached image should be aligned. If I extruded these there is no telling where they would go.
I think we may be talking about a different thing. By the way, I can't get a 3D polygon to "push-pull." I know how to do it. It just does not work on 3D polys...for me. I don't use it much because it turns it into a generic solid and is no longer editable as an extrude.
And, Jeff, I apologize if you think my difficulties are "claimed," implying they are not real. I don't know where you get off with such boorish comments, but I can assure you that I know what I'm doing when it comes to Vectorworks. Perhaps you are just smarter than me and I'm missing something obvious. Please point me to a tutorial where this is explained.
  • Dislike 1
So, 2D polys are not 3D, but they exist in 3D space.
I don't tend to use the 3D Poly tool unless I am trying to create an object using/snapping to existing geometry or 3D Loci. In a right Iso view using either the 2D or 3D Ploy tools, I can draw a shape and then push pull to a desired extrusion. The Extrude command will work on the 2D. I have the push/pull mode and the push/pull combine modes activated.
Wow, you read a lot into a comment just trying to give you a hand.
Good luck buddy, I'm done dealing with triggered individuals.
By the way, Auto Plane is greyed out in my workspace.
Sounds like your Automatic working plane is broken.
To quote: "Yes.  I don't know why you have such claimed difficulties..."
If that is not boorish, I don't know what is. I'm leaving this forum and moving my questions to one on Facebook. Going forward, I'll just use this VW site for software information, etc.
Don't bother replying, Jeff, I won't see it.
