btgroves Posted August 22, 2024 Share Posted August 22, 2024 (edited) Hello all, I just updated to SP7 this morning, noticed something that may have been happening for a while but I just discovered it... We layout our line drawings within ConnectCAD with a standard viewport scale / sizing, because of this we have unique design layers for each viewport that will ultimately end up on its own sheet. We also do this for the unique Cable Arrow visibility that is automatic when drawing a circuit across Design Layers. I created 5 Panels using the Connector Panel tool, they only show up in the selection drop down box for "Edit Device Array" if I'm actively on that Design Layer, regardless if I have the visibility on in the OIP on the right. If I navigate to a different layer, they no longer appear in the drop-down menu At one point, I was encountering the same issue just while using the Connector Panel tool, but I've since quit and re-launched VWX and can't seem to replicate that issue. Screenshots below for reference. Edited August 22, 2024 by btgroves Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 23, 2024 Vectorworks, Inc Employee Share Posted August 23, 2024 Hello @btgroves, Thanks for reporting. I will log a bug about this and we will work on a fix. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
btgroves Posted August 23, 2024 Author Share Posted August 23, 2024 Thank you! @Nikolay Zhelyazkov Quote Link to comment
