Kong Posted September 16, 2004 Share Posted September 16, 2004 If the Text to find and replace command can do a lot word (or charactor from type one). well. for easy to type symbol charactor by key words and replace. else i think it will solve problem from GSEmul with GSEmul-J combine (or other problems). example : Text Map to find and replace command. it like Text to find and replace + Plant Database + Name Standard Setup... Browser Text file ... for a lot Text find to replace and for any local charactors can not type an one this in Setting box but it can type in PadNote Option ... same options in Text to find and replace Box ****************************************** Text Styles ... for Easy edit texts on a lot Layer or Sheets and will can spec more fonts in plug-in objects(or dimension lines)., like texture styles by classes. Good luck... Quote Link to comment
Kong
example :
Option ...
Text Styles ...
Good luck...
0 answers to this question
