Marc Posted April 15, 2002 Share Posted April 15, 2002 Is there a way to keep the three D grid visisble?At all times. Thanks M Quote Link to comment
Vectorworks, Inc Employee Biplab Posted April 15, 2002 Vectorworks, Inc Employee Share Posted April 15, 2002 I am not sure about the 3D Grid terminology - I am assuming you are meaning the control vertices of a NURBS surface. You can turn the control vertices on from the OI Palette by checking Show Vertices check box. Let me know if I am way off of your query. Quote Link to comment
Marc Posted April 15, 2002 Author Share Posted April 15, 2002 I was referring to the axis indicators. It is difficult to know what direction is which. Quote Link to comment
MikeB Posted April 15, 2002 Share Posted April 15, 2002 Check under VW preferences under 3-DThere is a box to check called"Show 3-D Axis Labels" Is this what your after? Quote Link to comment
MikeB Posted April 15, 2002 Share Posted April 15, 2002 Also go under the "Page" menu to the "Set Grid" and Check the "Show Grid" box. Now you will see the ground plane with X and the Y directions labeled. Quote Link to comment
Marc Posted April 15, 2002 Author Share Posted April 15, 2002 Thanks, it's been a while and I forgot all about the show grid. Still it would be nice to have three axis. And maybe also for each object. Quote Link to comment
