spettitt Posted August 21, 2024 Share Posted August 21, 2024 (edited) Here's a quirky one. I would like to have my python script query data from our Microsoft 365 tenant. I have this working fine in my standalone python desktop app, but I'm running in to an issue in a VW script context with loading a browser. The msal library for python deals with secure tokenised login to 365. You call the command 'acquire_token_interactive' and it should launch a browser for you to authenticate with your tenant credentials. Once you've logged in to your company 365 tenant as you, the browser closes and hands the token to your script for your session. The issue is that it seems when it's time for the browser to launch, Vectorworks crashes. I don't really mind whether it opens the default WebDlg or can be re-directed to an external browser. Here is my code. I get the AlrtDialog of 'attempt interactive', and then VW quits. Does anyone have any ideas that might stop Vectorworks crashing and allow the browser to open please? import vs import logging from io import BytesIO import Marionette lib_OK = False try: import msal lib_OK = True except: msal_whl = "https://files.pythonhosted.org/packages/ab/82/8f19334da43b7ef72d995587991a446f140346d76edb96a2c1a2689588e9/msal-1.30.0-py3-none-any.whl" bool = Marionette.VerifyOrGetLib("msal",msal_whl) if lib_OK: import requests class Ctrller_365_Client: def __init__(self): self.app = msal.PublicClientApplication( client_id="redacted for forum", authority="redacted for forum", token_cache=msal.SerializableTokenCache() ) vs.AlrtDialog('auth app exists') self.token = None def authenticate(self): # Attempt to load token from cache accounts = self.app.get_accounts() if accounts: logging.info("Account(s) found in cache, attempting silent login.") self.token = self.app.acquire_token_silent("User.Read", account=accounts[0]) if not self.token: vs.AlrtDialog('attempt interactive') logging.info("No token in cache or token expired, logging in interactively.") self.token = self.app.acquire_token_interactive(scopes="User.Read") if "access_token" in self.token: logging.info("Authentication successful.") else: logging.error(f"Authentication failed: {self.token.get('error_description')}") raise Exception("Authentication failed.") Edited August 21, 2024 by spettitt Quote Link to comment
