Jonk Posted August 21, 2024 Share Posted August 21, 2024 Hello! I've done a 3D model of some concrete wall footings and I want to be able to report back the volume of concrete for each extrude. That is the easy part and I've been able to do that. However, I'm trying to work through the criteria and reporting and I can't seem to figure out how to get the worksheet to report back both the symbol name and the volume of the extrude inside of that symbol. I'm attaching a file that should help. This is a 2024 file from a machine running windows. Thank you! Footing Test.vwx Quote Link to comment
Pat Stanford Posted August 21, 2024 Share Posted August 21, 2024 Can't do it using the built in functions. You can do it using a worksheet script. Take a look at this thread and ask if you need more help. Quote Link to comment
Jonk Posted August 21, 2024 Author Share Posted August 21, 2024 dude @Pat Stanford you are an absolute magician. This worked perfectly! Thank you!! Quote Link to comment
