Panel Builder
I'm still wrapping my head around Panel Builder/Panels and I was wondering two things:
1) How do I update panel connectors after the panel is created? If I click on the Panel Builder tool in the Object Info palette it asks to create a new panel.
2) Is there a way improve the look of the default panel graphic that's generated for schematics or can I tie the panel to a custom schematic block? We typically are used to seeing panels presented a little more similarly to device blocks (see attached screenshot).
Hello @scobb,
- Double click on the panel layout object to enter it and edit its panel connectors directly.
- It is not possible to customize the graphics of the created schematic device at this time. As for linking the panel to a custom device, this is possible but the device must be of the same device type. Then you can select the device from the OIP of the panel layout.
Best Regards,
Nikolay Zhelyazkov
