Peter Z Posted August 20 Share Posted August 20 Hi Guys, I hope everybody is well. Often, a circuit is shown as "??? Unknown Signal Type". Mostly because I had a missmatch in port assignment or when I copied the circuit from another page. Anyway, when it shoes as "??? Unknown Signal Type" and i fix the mistake, I have to update the circuit. I usually shift it aside and back (Shift+CTRL left/right) Is there a better way, maybe a command? Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 20 Vectorworks, Inc Employee Share Posted August 20 Hello @Peter Z, How do you fix this? If it is by editing of the sockets, then it is expected that the circuit signal does not change, as we auto calculate the signal based on the sockets only when a circuit gets redrawn/created. Best Regards, Nikolay Zhelyazkov Quote Link to comment
Peter Z Posted August 20 Author Share Posted August 20 Hi Niko, that is clear for me, my question would then be, is there a "recalculate" command for the circuit? Basically when I shift the circuit back and forth, I guess it has the same effect as redrawing the circuit? Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted August 20 Vectorworks, Inc Employee Share Posted August 20 Just now, Peter Z said: Hi Niko, that is clear for me, my question would then be, is there a "recalculate" command for the circuit? Basically when I shift the circuit back and forth, I guess it has the same effect as redrawing the circuit? - Yes. But recalculate is different than redraw. I think that there should be a script that I have made somewhere in the forum that automates the nudging up and down which you can use. Actually, I think I found it, so you can try it. MoveCircuits.vwx 1 Quote Link to comment
