  • 4
Modify point elevation on slabs.
FranAJA
I haven't found anything within VW so far that can make this operation simple: moving a point of a slab up or down.
I find this operation quite complicated with slab drainage. Even if I only need to raise a point of a slab by just 100mm, I end up spending hours trying to figure out how to do it. This is a vital operation for BIM, and I wonder why it hasn't been implemented yet (or if it exists, I don't understand why it's hidden).
I wish it were possible to move any point of a slab along the Z-axis, just like we can do in Revit. It's not feasible to always use drainage, which is the most complicated tool I know in VW.Capture.thumb.JPG.b7642156c190ccec3eb1581bc0746d77.JPG
4 answers to this question
Yesterday I used the Drainage Option for Slabs for the first time.
I have one Floors Slab that has a sink.
I was quite surprised that the drainage pushed the edges of my slab upwards
instead indenting the sink.
Beside the need to do some math to get it as expected, I also needed to
create again a Slab Style duplicate just for that room with the sink.
@FranAJA and @zoomer: I did some testing on hardscape as I run into a project where I need this tool a lot. I made 3d-polygon(s) and adjusted vertex z-value to fit the shape I needed., then created a hardscape in "align-mood" same shape as polygon using snap to object.
I keep my 3d-polygones (or extrudes or any other valid align-shape) in a separate layer to make it easy to update and controle. (specify layer in hardscape-setting).
I also tried to use "create object from shape, it works but I got some issues when reshaping them, also it creates one hardscape for each polygone rather than one single hardscape controlled by more than one polygones.
Note: The slabs is by default exported as hardscape to IFC but this can easily be changed in the info-palette under data tab.
Hope this is useful for you until a more intuitive slab tool exist...
