APE Design Ctr Posted September 3, 2004 Share Posted September 3, 2004 It would be nice to have more 3D options, like export to 3DS, or Max, and even Cinema 4D. Quote Link to comment
0 APE Design Ctr Posted September 3, 2004 Author Share Posted September 3, 2004 Thanks, I wanted to import to Cinema 4D without the plugin. Quote Link to comment
0 Guest Posted September 4, 2004 Share Posted September 4, 2004 You can export to Cinema 4D if you have the plugin. You can also export to 3d Studio Max by using the IGES or STL or even DXF/DWG export options. Quote Link to comment
0 Neelish S.R. Budhia Posted October 10, 2004 Share Posted October 10, 2004 dxf, iges and stl have there limitations - especially if you require a 3DS file to use with a program other than Max... In lightwave and Maya I have found that elements move around, and 3d objects are no longer 3d, but 3d lines... Quote Link to comment
APE Design Ctr
3 answers to this question
