LargoMargo Posted August 15, 2024 Share Posted August 15, 2024 is it possible to create a quadra circle like a shell in vector works? I need this kind of organic volumen for my concept, but i have no idea.. to make it with Vw. I have some expiernce with nurbs curve and circle volume, but its not possible to create my concept with this kind of tools. Please help me, if u know a way:)! Quote Link to comment
Pat Stanford Posted August 15, 2024 Share Posted August 15, 2024 I don't have any idea of what a "Quadra circle like a shell" is. Can you post an image of something similar to what you are trying to create? Quote Link to comment
Elite Exhibits Posted August 16, 2024 Share Posted August 16, 2024 ¿ Shell ? Peter Shell.pdf Quote Link to comment
VIRTUALENVIRONS Posted August 16, 2024 Share Posted August 16, 2024 We covered this in the petal shapes last week. I don't know how to bring that forward, but look for "shapes found in nature". Quote Link to comment
VIRTUALENVIRONS Posted August 16, 2024 Share Posted August 16, 2024 Is this what you are interested in. Quote Link to comment
jmcewen Posted August 16, 2024 Share Posted August 16, 2024 Or like this? Pic below and file attached to play with. Draw your base polyline profile. Extrude it a little, but not as tall as your intended shell. Taper thje top face with the deform tool taper solid and symmetric mode so that the point ends up over or near the hinge side of the shell. in side view, bend thte tapered shell in the bend solid mode of the deform tool. turn off the symmetric mode for this or you will get a mess, but turn on finite length. First click the bottom of the hinge side of the shell, then the top of the hinge side of the shell. drag the top around the hinge until you find something that looks good. shell sample.vwx 3 Quote Link to comment
bcd Posted August 16, 2024 Share Posted August 16, 2024 6 minutes ago, jmcewen said: Or like this? Pic below and file attached to play with. Cool, & then twist in plan please if you can Quote Link to comment
jmcewen Posted August 16, 2024 Share Posted August 16, 2024 Twist the model or twist the view? Not much luck using the deform tool for another wicked operation. but if you just want to see a plan view here it is. i might have better luck if the flutes in the shell were not so extreme, but extreme was the fast way to draw this today. Here is a orthographic top view of a quick smooth shell that I was able to bend in the other axis after the first aching bend, but it doesn't look too exciting. just a proof of concept really. it look s like the view is skewed, but it is straight down. Initial polyline profile was a plain circle with a rectangle added to it. Deform tool will get you out of a lot of jams, but usually also puts you squarely in a dead end. Sometimes that dead end is good enough tot work with though. 2 Quote Link to comment
bcd Posted August 16, 2024 Share Posted August 16, 2024 14 minutes ago, jmcewen said: Twist the model or twist the view? Not much luck using the deform tool for another wicked operation. but if you just want to see a plan view here it is. the model, but nice work ☑️ Quote Link to comment
VIRTUALENVIRONS Posted August 16, 2024 Share Posted August 16, 2024 1 hour ago, jmcewen said: Or like this? Pic below and file attached to play with. Really slick. I never use these tools, good to see what can be done with them. Quote Link to comment
jmcewen Posted August 16, 2024 Share Posted August 16, 2024 1 hour ago, bcd said: the model, but nice work ☑️ 4 minutes ago, VIRTUALENVIRONS said: Really slick. I never use these tools, good to see what can be done with them. .Thanks guys, but only use it as a last resort. I often get stuck in a process that fails 9 or 10 steps later if I rely on deform. Efficiency, simplicity, and patience are key to its use Quote Link to comment
jmcewen Posted August 16, 2024 Share Posted August 16, 2024 Never underestimate the power of procrastination. Problem solved by reordering the operations and removing the hinge form the base model. it can be modeled separately and added later. . twisted shell sample.vwx 2 1 Quote Link to comment
bcd Posted August 16, 2024 Share Posted August 16, 2024 I can almost hear the ocean 1 Quote Link to comment
jmcewen Posted August 16, 2024 Share Posted August 16, 2024 1 hour ago, VIRTUALENVIRONS said: Really slick. I never use these tools, good to see what can be done with them. Sound like me with NURBs. But couldn't his same process be done with a bi-rail sweep. it seems to be essentially the same operations using different tools to me, but my NURBs execution is clumsy. if you start with a base profile and use 2 tapering/ twisting/curving rails, it seems that you should get similar results in my mind (if operating in NURBSs is a more comfortable environment.) My clicks just never seem to land where I want them to when I use NURBs.... Quote Link to comment
VIRTUALENVIRONS Posted August 16, 2024 Share Posted August 16, 2024 Sitting in the middle of a lake at the moment on our boat. Refreshments are available. Let’s talk NURBS tomorrow, great work. Quote Link to comment
VIRTUALENVIRONS Posted August 17, 2024 Share Posted August 17, 2024 There are several ways you could go about this using the NURBS tool palette, but bi-rail sweep is a limited tool. Loft Surface>No Rail is the key tool for most applications. I downloaded your file. That last shape is really amazing. BTW, I think we/you have hijacked this thread, but it is interesting. I don't think the geometry we are discussing is what the client is looking for. The Scallop shell is more of a extrusion than a sweep or bend as you have shown. I recreated some shapes like yours using Loft Surface. I twisted some curves, expanded another and morphed from a square into a scallop. This is what NURBS brings to the table. Quote Link to comment
grant_PD Posted August 19, 2024 Share Posted August 19, 2024 Love all this stuff, then I try it and my brain just craps out. How would I do something simple like taper these rectangles along this curve? file attached. taper.vwx Quote Link to comment
VIRTUALENVIRONS Posted August 19, 2024 Share Posted August 19, 2024 Not sure exactly what you mean. Can you elaborate? Paul Quote Link to comment
VIRTUALENVIRONS Posted August 19, 2024 Share Posted August 19, 2024 Is either one of these what you mean? Quote Link to comment
grant_PD Posted August 19, 2024 Share Posted August 19, 2024 I have a path, on one end I have a rectangle at 1"x .25" high. I want that rectangle to move along that path and end up 12" high at the end. I've tried loft w/ 1 rail and it won't work. Quote Link to comment
grant_PD Posted August 19, 2024 Share Posted August 19, 2024 yes! what steps am I missing? why won't loft w one rail work? Quote Link to comment
VIRTUALENVIRONS Posted August 19, 2024 Share Posted August 19, 2024 Don't use Loft Use EAP with the exponential scale. Also, something is wrong with your rail curve. Use Rebuild NURBS in the 3D Power Pack. Don't change any points, just select the curve, Rebuild and OK. Quote Link to comment
grant_PD Posted August 19, 2024 Share Posted August 19, 2024 EAP w/ exponential seems so hit an miss tho. I was able to do it by extruding and then taper face. Quote Link to comment
Jeff Prince Posted August 19, 2024 Share Posted August 19, 2024 15 minutes ago, grant_PD said: EAP w/ exponential seems so hit an miss tho. I was able to do it by extruding and then taper face. Assuming your curve is agreeable, the easy way to do this is draw the elevation, extrude it 1", then use the Bend tool. Quote Link to comment
